Unfortunately I don't remember at all how those fuses looked like. If they are these:
...they are TR5 miniature fuses, and every decent component supplier should have them.
If you didn't even have the red standby LED, the transformer is a suspect. Just measure the windings for continuity and you'll know.
The transformer will be easiest to supply from B&O. I suppose
it is a stock model from some manufacturer, but trying to find a pin and
footprint compatible replacement - and somebody who agrees to sell 1
pcs of them - will be a lot of work!
BTW, the internal damping foam kit should be available as a spare part as well and not too expensive. May not be worth it though, if you don't plan ever digging in there again!
