I thought I would start a new post as the last one was pretty much on another subject.
Again here are some pictures of my restoration work of the 2500 cubes and Beovox 5000 type 6223.
Today I received Beomaster 5000 (tuner) which I must say is in fantastic condition. I don't know if it actually works as I don't have anything to hook it up to (yet). Does anyone know how to hook up the cable TV line to the antenna input; I've never saw this kind of connection?
I also though that the tuning slider would be a bit more smooth (the wheel slides a lot and it requires quite some pressure to make it move) is this due to age and can something be done?
Now I will probably have a long wait before I can find the Beolab 5000 and perhaps a suitable turntable. Maybe I'll go for a Thorens as they are quite easy to come by (even the old ones)
P.s. Beosystem 7000 is still going fine.
Cheers
Andrew
