BEOVOX 2500 CUBE REFURBISH
hi all,
this was my first refurbish work. i've chanced the capacitors, speaker cables and repainted the cubes with antrazit matt finished color at some parts.
unfortunaly the previous owner drilled some holes, very unprofessional as well, in the original stands to mount the cubes at the wall... i was looking on ebay for a donor pair, but the prices are to high, even defective cubes. the only solution was to rebuild them (thanks to my father). the stands are made from chrome-plated brass. i've decided to simplified the undersurface design. one original foot weight about 323g, the rebuild weight now nearly twice, exactly 592g. ;-) now the cubes are more inured for overturning...
best regards
dario
original and rebuild stands.
Super job, well done.
thanks, it tokes me time, but the result is not bad... ;-) good things need while, or how is this saying in english?
Patience is a virtue?
If something is worth doing, it's worth doing well?
Good things come to he who waits...
Superb job Dario!
Chris.
Fantastic job, Dario! πŸ€’
Well done, they look superb.
CraigπŸ™‚
also a nice description.
that's it!
Medogsfat wrote:
Superb job Dario!
Chris.
thanks
