You wrote : ??? could you explain a bit ???
Despite being developed almost 15 years ago the Beolab 5 is still a very capable speaker, most likely never to be matched by the company!
It is great because it was allowed to have volume, power, and great drivers! And the Analog Devices Sharc DSP was state of the art at the time of its conception. But back then the prevailing digital source was the CD and you ended up with the somewhat peculiar connection arrangement, and even though the volume control DAC was implemented in the exact right location, it only works in the digital mode...
Since then, the Bluray arrived, and with Bluray,- Multichannel HD Audio, which in many cases actually supersedes most conventional digital music sources. Not only quality wise,- but especially when it comes to the extreme dynamic range,- movies!
And as one of the few speakers around, the 5 not only copes,- it freaking shines across the audible spectrum, and delivers the LFE punch with precision and ease!
That is.... If its feed through the digital input! The Powerlink simply wasn't designed for this, every single time you attenuate the analog signal by 6db you lose 1 of the 16 bits of resolution! Which you will do, since the volume control is kicking in before the Powerlink output!
The architecture of the 5 is so special that you would expect B&O to support it, but no! Even though it's presented with the TV lineup and you might expect the digital TV audio engine to just be sitting there eagerly revving up ready to release its pristine digital content, you will forever be looking for those digital out connectors.... you do of course have 8 Powerlink,- what an unforgivable oversight (at best).
And to top it off, the newer Beosystem 4 doesn't even support the audio (CD) part anymore. For real? This is a 10000$ speaker without any support for its native technology from the company that proudly built it and still today publicly acknowledges its digital qualities?
I would still recommend the 5 any day and the Beosytem 3 for that matter, but both will need some serious counseling from Mr. Intel in order to work together in the best possible way.
