Beolab 5 setup
Hey Forum
I’m a proud owner of 2 Beolab 5. Regarding the sound quality I’m very pleased with them, but I’m still struggling with the best setup.
For my ears the best was to feed them, is the digital input. And I like the idea of having an all-digital signal path straight to the loudspeakers, without any unnecessary D-A-D… conversions.
Since there is still no solution to use the digital input with original B&O equipment (without CD as source or the “having a CD in the Beosound running, while the beolabs get the digital signal from another digital source” - workaround), I’m using them in the Opt. 1 for the non B&O equipment use. So I control the volume with the beolab 5.
This works fine, as long as you don’t want to have surround setup.
My priority is definitely stereo listening, but I also want to enjoy my homecinema.
Therefore I use an av-preamp connected to the analog in of the bl5 (and via trigger cables to a beolab 10 center and 2 beolab 8000 as rears). In this case I control the volume with the av-preamp.
My problem is now, a total mismatch of the volume from the fixed digital signal, to the volume controlled analog signal. The analog is very quiet compared to the digital in (which is clear, since the bl’s are expecting a fixed line level). So I have to set the starting volume of the bl’s very high, to get the same volume as the other speakers in the system.
So when I want to listen to music digitally, and forget to turn the volume down before starting the music (or when some of the digital connected device starts playing for some reason during a video session), it’s always close to get an heart attack.
My wish would be:
Getting a software update for the beolab 5 with the following behavior when opt 1 is set:
Pressing “Radio” on the remote will turn the Beolab’s on and activate the analog input.
Pressing “CD” (for example) on the remote will turn the Beolab’s on and activates the digital input.
And an individually startup volume setting for each of this inputs (to which it always jumps, when I change the input).
So a direct source select with separate volume settings.
It would be possible then to listen to music digitally, control the volume with the beolab’s. and when I want to change to the surround setup, just pressing “Radio” and it would change the input to analog and the volume would be automatically the same as the other speakers.
Ahhhh, I dream of it J
This would not be a major change in the software, but make the handling, the flexibility and the future safety of the Beolab 5 a lot better.
What do you think about it? Anyone having the same issues? Or a solution (without workaround, I don’t want to have a workaround I a system in this class)?
Does someone thinks they will support the Beolab 5 with updates in the future?
Sorry for the long post, and best regards
Mike
Think about feeding a powrlink signal to the 5's, but use Flac MQA files through the Meridian Explorer 2 DAC (much better than the 5s older DAC.
You can then decode MQA files, which will be the finest stereo files you can get
This is what I do
B
and connect the output to the aux in of a beosound?
or how is your complete system?
regards
Mike
Nah that wont help, due to the DSP inside beolab 5 the speaker will convert the analog signal from the Meridian dac to digital again and then convert to analog.
To get the best sound from your BL5 is to feed them with a good digital signal. The dac inside the 5 is still good in my opinion. I cant complain with the sound.
this is exactly my opinion. the dac in the beolab 5 works perfect :-)
using a second external dac never can improve the signal quality....
I don't want to do all these unnecessary conversions.
so I really want to feed them with a digital signal, for music listening. the speaker is perfect in my eyes, but the usability could be better nowadays...
in 2003, the best and most common digital source (I guess) was the cd. and at that time, the software configuration of the source selection was ok. but today, I would wish for a different behavior of the software.... than it would say, it's pretty flexible for the most of the future setups and up to date again..
Hallo Mike
This does not change you must change option, but lets you stream digital audio to BeoLab 5.
regards
Mike
Yes. Any Beosound with an Aux in.
Or...Use Creation App to access your FLAC files
I dont think the BL 5 converts the analogue to Digital and back to analogue.
Please confirm
As I understand it the Beolab 5s always convert the analogue signal to digital for the DSP and then back to analogue.
Please confirm
it most certainly does!
The internal DSP requires a digital signal in order to start working its filtering magic!
And that is why it is paramount to maintain the original digital signal all the way to the Beolab 5 DAC which also handles the volume control.
If you use the Powerlink connection the signal will already have been converted from digital to analog in the CD player, and once it reaches a newer Beosystem/Beovison it will again be converted to a digital signal, processed and then converted back to analog before being sent out as an attenuated analog signal!
The really bizarre part is,- since the BS3 NO B&O system will support the Beolab 5 in the digital mode, although it is still being sold and frequently featured in sales adds showing setups with current products.
I would be pretty disappointed if I tried to pair up a set of 5s with an Avant 55 or BS 4...
