Hello,
I have two Beograms (one 4002 and on 4004). I went through each one, cleaned and lubricated the chassis and the tone arm lowering mechanism. Everything was working for both after this step. However, after removing the main PCB for each to examine the caps, remove the old transport lock bushing fragments, and add new thermal compound for the transistors with heatsinks, I have run into two issues.
The first being that the Beogram 4002's motor will not spin - it is plugged into the correct port (the one closet to the front of the Beogram). The Beogram turns on and the tone arm works as intended, just the motor does not spin.
For the 4004, the unit simply will not respond to any command from the control pad - I even checked the fuses (both of which are fine). I really have no clue with this one as it was working before.
Does anyone have any suggestions? I am trying to learn to care and maintain these myself, but my knowledge of electronics is limited (I recognize that a tangential arm Beogram isn't the easiest thing to work on - that said I have made all of the service manual adjustments to a proverbial "T".) If you need more information/photos/video please ask!
Thanks!
