Beocenter 3500 Indicator Lamps
Hi again
The green Stereo light on my Beocenter 3500 has stopped working. I guess it’s just the bulb as everything else is fine. I found these threads recommending an RS branded bulb and saying it’s just a push fit. Does anyone know if I can remove the small screw under the lamp and get in that way, or is it a case or taking the deck off the top?
Have I got the right bulbs before I order as well please?
link
link
Thanks everyone for any help
Have found a pack of 5 bulbs on eBay. Have had a look at the front panel and it looks like it’s a top-off job :)
