Beomaster 3000-2 - replacement bulbs
 I have recently acquired a Beomaster 3000-2. Two of the bulbs are out on the front panel, but otherwise the amp is in great condition.  I desparately want to restore the amp to its full, original working state, but  I understand from my service guys that, not surprisingly, B&O dont supply these parts any more and that they are not standard parts that can be purchased off the shelf any more. Does anyone out there have any spares/old parts or a suggestion as to any companies that I could approach to custom-make some replacements. Thanks
I can supply new lamps of correct type and wattage.
Email me.
Hi Martin,
Thats great news. I am being stupid - where is your email address?
Andrew
click on "Dillen" and you will get there
Retired Printing machine technician Restored various 1960-70 items Rock and Roll music Collecting Vinyl Restored Jukebox Wurlitzer 1050
Hi asharland,
This is what I did when I had a Beomaster 3000-2 light bulb issue: I replaced it with a SMD LED that I soldered to a 680- Ohm current limiting resistor, which just fit into the light bulb socket...here are some pictures:
http://beolover.blogspot.com/2014/03/beomaster-3000-2-bulb-replacement.html
It looks quite original from the outside...
Enjoy!
Hi Harry
Thanks for this. This is very clever and very neat!
In fact, I think I may have sourced some replacements from a vintage fan in Denmark, but this is a great plan B.
Have a great weekend and thanks again
Andrew
RS Components carry them in stock! I bought six  ( I collect 3000/4000 Beomasters - eight at present!) for 'two thirds of not a lot' - changing a dud bulb for a new one is a doddle.
Thanks Danny. Thats good to know. What a great amp the 3000 is! I quite fancy getting a 4000 at some point too!
Andrew
Hi Danny (no relation I assume), thanks for the post point us to RS. They have lots of them with different current ratings, which did you find the most suitable?
I can't find any current specs on the one I took out of my 3000.
Cheers
http://au.rs-online.com/web/c/lighting/incandescent-light-bulbs/filament-indicator-lamps/?searchTerm=12v++Wedge+Filament+Indicator+Lamp&h=s&sra=oss&redirect-relevancy-data=636F3D3226696E3D4931384E44656661756C74266C753D656E266D6D3D6D61746368616C6C7061727469616C26706D3D5E5B5C707B4C7D5C707B4E647D5C707B5A737D2D2C2F255C2E5D2B2426706F3D3926736E3D592673743D4B4559574F52445F4D554C54495F414C5048415F4E554D455249432673633D592677633D4E4F4E45267573743D313276202057656467652046696C616D656E7420496E64696361746F72204C616D7026
The 3000 and 3000-2 receivers seem to me to produce a smoother sound compared to the 4000. I still use the 3000-2 I bought new in 1973 and it is as good today as the day I bought it.
That said, all three are great pieces of 1970's HiFi at its best, both in terms of design and performance and apart from the odd lamp bulb failing, are totally trouble-free if used on a regular basis.
