The problem is that the HDMI ARC is incompatible with the HDMI ARC on my new LG TV model. That is the opinion of my B&O dealer from whom I had bought another stage. And I prefer the TV more than the Stage. So I will look for other options.
Bang and Olufsen - online customer service.
I set up the stage I bought online. ARC to ARC and wi fi. My dealer didn’t change anything with the one I bought from him. He accepted a return immediately. I’m still waiting to hear from B&O about my first purchase, packed and ready to go back one day.
Set up? I followed instructions. Connected by Wi Fi.
Don’t know how the multiple posts were done!
What model LG tv how you bought?
Can you specify which LG-model you have?
I bought two identical TVs. And neither worked either with the Stage I bought online or the one I bought from my local dealer. They were among the cheapest of the LG TVs - LG49um7400PLB. And I have no wish to replace them with another LG model. It should not be necessary.
Some questions:
* Does it happen to all sources (tv tuner, hdmi sources and internal apps)? Sometimes the internal apps are not returned through ARC.
* Did you connect the HDMI-cable to HDMI 2?
* Did you use a high speed HDMI-Cable?
* Did you put Sound Output to ARC?
* Did you enable LG Simplink?
