cd player beosound A9
Hi all,
Do you have any suggestions/idea on how to connect a CD player to the speaker beosound A9?
Do you know if there is any airplay/bluetooth solutions that exist?
The A9 (4th-gen at least) has a 3.5mm analog/optical input jack behind the back plate near the power cord.
To avoid tethering a CD player by cable, you could remotely use an old/inexpensive M3's line-in, then JOIN to it from the A9. See here: https://forum.beoworld.org/forums/topic/beosound-level-beoplay-m3-multiroom-with-line-in/
