B&O Radio Migration Available now
Tapping my Essence MK II in the app, going to the radio section, I received the surprising but good information that I have the possibility to migrate tunein radio into B&O radio. So far I am hesitant to do so. I guess, some of the members here have experience with the migration weithin the beta version of the app? Maybe some have already migrated. Can you recommend it? Thanks for your advice! Kind regards, Rolf
Also available for the Moment!
I had a update to my Eclipse soundcenter yesterday and went looking for changes.  I noticed that B&O Radio was now a source that I can make specific changes to in the B&O App on the Eclipse. When I opened the B&O App on my phone it said I could migrate Tunein sources to B&O Radio but when I try to play a B&O Radio station I get told not supported on the chosen device, the Eclipse. Paul
Honestly….I’d wait a while. This does not seem to be 100% working yet. I did this a couple of weeks ago (beta update), when it was offered. See this thread: https://forum.beoworld.org/forums/topic/bo-radio-2/ One of my devices however, had not been automaticly updated, so I had to do this manually today. After that I again was prompted to migrate (although I already had done that back then and my other devices were working well with the B&O Radio). The first time I did it, my stations were completely mixed up - I had to delete all and build the list from scratch again. Naive as I am, I thought they had sorted this issue, so I did it once again……….with the same result as the first time. Because the list in the app is global for all (supported) devices, I now have to build the list once again ?   So, not saying that one should not do it now. But you should be aware that you may face the same problems and that you maybe will have to spend time recovering the list in the new B&O Radio afterwards.   I am very interested in hearing about the experience of other users….maybe this is just so in my case ? MM
I did it and regret it. 80% of the stations I listen to in TuneIn are not in B&O Radio which I am very very unhappy about.
It works on a M5 too, I can play Beoradio
A.K.A Capt’nGerard on the Discord
No, Tunein favs and Beoradio favs are still different. I only have 6 and 4 favorites
https://forum.beoworld.org/forums/topic/bo-radio-2/ One of my devices however, had not been automaticly updated, so I had to do this manually today. After that I again was prompted to migrate (although I already had done that back then and my other devices were working well with the B&O Radio). The first time I did it, my stations were completely mixed up – I had to delete all and build the list from scratch again. Naive as I am, I thought they had sorted this issue, so I did it once again……….with the same result as the first time. Because the list in the app is global for all (supported) devices, I now have to build the list once again So, not saying that one should not do it now. But you should be aware that you may face the same problems and that you maybe will have to spend time recovering the list in the new B&O Radio afterwards. I am very interested in hearing about the experience of other users….maybe this is just so in my case MM
Thank you for Sharing your experience. In my app every single device asks for migration confirmation. In the „beta case“ (thanks for the link) you are displaying that the migration will convert all devices present in the network at once (that´s how I understood it). Do you know, if this is still the case or can be done now device by device?
Kind regards,
Rolf
