Beosystem 2500: what to replace rotted foam in the speakers with?
I am restoring a Beosystem 2500 and its speakers. I am removing the rotted, old foam but I don't know what to replace it with. Can I buy a replacement kit from B&O direct? Or do I need to buy something else (and where)? Also looking for one of these black washers that go between the speakers bracket and the main unit... I have 4 screws but only 3 washers. Where can I get a spare? I *could* also 3D print a replacement of similar diameter and thickness but I'd rather get an original if I can.
The BS2500 does not need the sticky black foam. It even sounds better without the foam... something more clear. The system even stays cooler, the ventilation is a little bit better. You can remove it without replacement.
https://www.google.com/search?q=beosystem+2500+speaker+rebuild+kit&sca_esv=587313471&sxsrf=AM9HkKkbbsrr66AMlZ5yjBWwtK5gxWpyyQ%3A1701537151889&ei=f2VrZbLwNf62wPAP8sC5sAY&oq=beosystem+2500++speaker+reb&gs_lp=Egxnd3Mtd2l6LXNlcnAiG2Jlb3N5c3RlbSAyNTAwICBzcGVha2VyIHJlYioCCAMyBRAhGKABMgUQIRigATIFECEYoAEyBRAhGKABSIRYUPkXWME6cAF4AZABAJgBswGgAaQMqgEEMC4xMrgBAcgBAPgBAcICChAAGEcY1gQYsAPCAgQQIxgnwgIIEAAYgAQYywHCAgUQABiABMICBhAAGBYYHsICBhAAGB4YDcICCBAhGBYYHhgd4gMEGAAgQYgGAZAGCA&sclient=gws-wiz-serp
https://www.repairyourspeakers.com/en/foam-rubber-surrounds/bang-olufsen/b-o-penta-repairkit-rubber-for-repair-midrange-speakers/a-2479-10000016
