Beosound 9000 MK3 glass door open issue
Hi, I have a Beosound 9000 mk3 with two issues regarding the glass door mechanisme: 1) Pushing the glass panel button does not respond the first time, it requires several presses before the glass panel opens. 2) The BS9000 is in slant position and when it opens up the glass panel it stops halfway but the motor keeps trying, is it a belt issue?. If so where to find such  and is it easy to replace yourself? /Pindsen
See
Hi, Thank you. As far as I can see Beoparts-shop does not have a belt for a BS9000 and I am a little unsure if those sold on Ebay are correct in specification (Maybe Dillen knows)? /Pindsen
Hi Pindsen, did you find a belt in the end? If so could you share the source please as I’m in the same boat looking for a new belt. Suspect many owners will be eventually and I don’t know where one can order new parts from B&O. Thanks
Hi BeoMedia, I bought this belt, more than 1 year ago, on ebay from this shop:
