Beoport/Beoplayer
Hello, I have a pc, and prepare a NAS for media, linked on the internet-local-network with the BS5-BM5. And root everything through the ML network to other BO-devices in the house. Someone can tell me of one of these sofwares, Beoplayer, and Beoport can still be used on PC-W10? (I also have still a Beolink-PC2 if still useful .. to link on the ML network directly). I have the impression, those softwares doesn't scan all ripped CDs. Tehy are in st same folder, but can't be seen on the Beoplayer interface. Scanning doesn't help. So I uninstalled it, then installed Beoconnect, and wiht MS-Media Player is see all of them, but the interface not really BO ... And I can see the contents of the BM5 without logging on to it! I liked the remote design of Beoplayer, so is there some other "sexy -BO" solution to use on pc?
Beoplayer runs fine on my 32-bit Win10 PC, although I haven't actually connected the Beoport/PC2 for a while for a fuller check.
Hello, Beoplayer works on W10 in compatability mode. I'm not sure that Beolink PC2 driver can be installed on W10. Anyway it's now a bit useless, apart if you with to listen to your B&O sources on your PC. I never had a problem with ripped CDs. Are you sure that your ripping parameters are OK as Beoplayer does not read all formats? Kind regards, Yann.
Infected at the age of 13 by a BG 4000 in Dad's Hifi shop.
This thread reminded me that I still have Beoplayer installed on my PC - not connected to anything else B&O (apart from the A2 Active that I use as a speaker for my desktop). Playing music on it now! (from my QNAP NAS)
But you do have to tell it which folders to scan:
Hi, Beoplayer works fine on a Windows 10 64 bits PC. The installed version is 5.04. Yann.
Seems to be running fine on my 32-bit Windows 10 also
Further to the above, have a look at this thread and maybe try the Registry Editor solution (gerard's 5 Feb 19 post):
How do you guys install Beoplayer 5.04? I am using windows 10 pro 64. With me it shows at registration (picture)when I made a selection: -Beomaster 5 -Beomedia 1 -None Now N.Radio does not work. Who knows what causes this? regards, Roland
I get those messages too, but I don't have an actual Beoport/PC2 connected to my PC at the moment.  N.RADIO works for me, but there are only a limited number of stations - one per country (but they play fine, so it must be connected to the internet). From distant memory I think that if you install Beoplayer with a Beoport/PC2 and connect the cables at the specified time in the installation process, the software automatically asks you to 'Register' the SW online (with B&O?)  This will then get rid of the 'Internet Connection Not Available' message and also allow N.RADIO to download a greater number of stations. It might not be possible to Register the SW with B&O any more - I am not sure.  I haven't used it properly since about 2014.
