BEOPORT can not register and connect ( as consequence) to Net Radio
I had to replace my old PC connected to BEOLINK PC and for compatibility I used WIN 7 -32.
BEOPORT (5.04) installed smoothly and worked fine but:
- no request for BEOPORTAL registration.
- no netradio availability ( due to the lack of registration).
I repeated the installation thee or four time no changes, the step when it asks for my email in order to register is skipped.
The PC is connected to INTERNET no special antivirus are installed.
The Masterlink works ok with the Net Music, but not Net radio.
I contacted BEOCARE and I got this answer:
Dear Mr. Mantineo,
the reason for that is that the provider of the internet radio service (v-tuner) has closed down the website. So you can only use your BeoPort without this functionality.
Best regards.
Still my BEOVISION AVANT 55 connects whitout any problem to NETREADIO ( but it is not connected to masterlink)
I had exactly the same problem but B&O support sent me a link to download a registry patch to fix and it all works ok now.
Paul
Paul
Why not attach the link here for all BeoPort users ?
it fixed the problem and several radios are accessible.
I am puzzled by the answer of  BEOCARE
alfio wrote:
Sadly BEOunCARE
I got a very quick and accurate response when I raised the same problem it must be who picks up the case. Paul
Or timing if they changed policy.
You would have thought any tech would first check for previous occurrences and their solutions !
Thank you for the file!
Thank you for the file also from me.
I had the same problem with BeoPlayer on Saturday but no time up to now to investigate further.
