Speaker for BM800
Hi, The speaker seems special in the Beomaster 800, it has a 50R resistor built-in and is hard to find a replacement for. I have a BM800 where one of the speakers are dead (infinite ohm across coil), so either I find a BM800 I can take the speaker from or I find an ordinary speaker (e.g. 4 or 8ohm) and add a series resistor to it. Do any of you know where to find a replacement speaker (it is 13cm wide and 7,5cm height). I have also tried to see if other Beomaster have the same speaker, but cannot find any - or have I overlooked something? /Pindsen
Here are pictures of the speak. It is 13cm wide, 7,5cm height and diagional between upper left and lower right screw are 12,7cm.
Here are pictures of the hole in enclousure.
