just working on my BM8000 which just doesn’t want to start. I can hear and see 7RL2
working its guts out but just wont close. I have been following the connecting trail and it should get about 24-25VDC from P51-pin2 but I can only get about 19.8VDC !
would it be fair to suspect 6IC9 ?? Both relays are fairly new which should exclude them as the problem.
6IC9 = BD676 and the question is are these known to fail ??
I have gone over board 7 but all tested fine - both 10W 5.6Ohm resistors are fairly new.
looking forward to your comments and pointers.
thank you
ALF
