When I start a record, or tune in a radio channel, or use my phone as a source, the right speaker is sparkly and fuzzy, and sounds terrible. This is fixed either by banging the amplifier - or. and I'm not sure if this really is the fix - by waiting for the amp to heat up. I'm not 100% it's fixed when it's hot, but I've gotten the feeling that the problem is significantly less likely to pop up then. This is not a speaker or a wire issue, sadly - I've tried switching them but it really is the right channel that is the problem. It's also an on-or-off kind of thing, either the problem is there and very noticable, or it works perfectly and sounds great.
I'd appreciate any help or suggestions or ideas of what might be wrong.
Thanks!
