Beomaster 4400 front disassembly
Hi, How to disassemble the front of a Beomaster 4400? In the two sides an undersunk screw can be removed but that does not loosen the upper front with the sliders because it requires to also remove the sccress in the middle and they are impossible to grab with a screwdriver - so how to remove the two screws in the middle? A solution could be to remove the whole front but that requires to remove the undersunk screw hidden behind the upper front part? Looking in the service manual does not help. Any good suggestions? /Pindsen
The two screws can be accessed from below at an angle, through holes and passing boards etc. Martin
As Martin says or use an angled (90 degrees) screwdriver, in mine they were missing
Retired Printing machine technician Restored various 1960-70 items Rock and Roll music Collecting Vinyl Restored Jukebox Wurlitzer 1050
Hi, Okay thanx. They are not easy to get access to in general. /Pindsen
You might take a look at
Thank you, that makes it clear. It is impressive how much effort he put into his restoration projects :-) /Pindsen
