Beomaster 2000 Type 2913 - Hinge Damping Grease question
Hi! I am the original owner of a Beomaster 2000 Type 2913. I have noticed that the lid pops up quickly instead of the slow opening I remember from when it was newer. I understand you can apply hinge damping grease (on order from Danish Sound Parts) but my question is how and where? I have removed the top portion of the 2000 (contains hinge and control panel) but other than the far left and right hinge (where it appears aluminum), I'm not sure where else to apply the grease. Any ideas? The service manual doesn't mention anything about it. Thanks!
Brian
I have my 2913 open for service now as well. I think the lids are dampened by a round device inside which a lever gets dragged through grease, or possibly just plastic friction.
But the key aspect is that the lid hinge needs to be connected to this round dampening device via a thin cord. Do you see any such string or cable? It will be the opposite side from the spring system.
Essentially the spring on one side is always trying to pull the lid open, and the cord connected to the dampening device on the other side slows it down once the Programming button is pressed and the spring contracts, opening the lid.
On my 2000 the cord had jumped one of the pulleys, but was still wound round the smaller metal axle.
Could also have a wrong spring for the lid.
When wall mounted, the spring is to be replaced by a stronger type to counter for the increased force needed to lift the lid.
Another thing to check -- when you reinstall the top, the white plastic part on the grease-dampened cord has to fit between the two black plastic tines of the hinge mechanism. During the time my spring assembly (on the other side) was broken, I had the receiver apart a few times, and probably missed inserting this correctly -- but I didn't notice because the lid wasn't lifting at all! :)
