Beomaster 1900 IL1 Testing
Hello, The input signal is not reaching the balance potentiometer It is stopped at Test Point 200 or 300 and not going through R226 and R326 I suspect IL 1 to be faulty and would like to know how to test the lamps inside Thanks a lot for the feedback   Alain
I could measure the IL1 lamp resistance between emitter TR24 and 15 V and found 17,7 Ohms is this value OK? If yes the problem is elsewhere, any thought?
hi traverso, IL1 or the LDR devices inside the volume control (8002293) could be the problem. Take the cover off the volume control and see if the lamp illuminates. Did you also check the contacts on the Balance control slider? -sonavor
Hello, Thank you for the help I used a one Khz tone generator connected to the recorder input  and the signal arriving at the balance control is very low I will open the LDR by tomorrow for checking Alain
The lamp is probably OK as measured 17 Ohms However I have ordered a repair kit for this LDR By the way, is there a trick to remove the cover of this LDR? Is it glued or just clipped?
Actually I unsoldered the LDR, more easy to open it The metal cover is glued to the black plastic support see attached picture The lamp is dead
The LDR components were the culprits I used a repair kit from Beoparts and put back the LDR in the 1900, everything is fine The 1900 is back to life and sing again Thank you Sonavor
