I think it might have to do with the sequence the plugs are insertedI might have to ask if you do this with the system powered on? Best practice is to power down both the Main room system and the link rooms that has a local power lead to avoid mal functioning.
Should I get a speaker cable instead of the DIN to connect the pentas to each other?No not sure that would work. The optimal connection for the Pentas are Powerlink.
