BL3500 and the MCL/PL connector
I know, this topic has been going on again and again. Can the MCL/PL connector on the BL3500 be used for direct connection of a iPhone/streaming device/ TV etc. and can it be turned on automatically?
To start with, I don’t know if this thread will answer these questions? But I got so inspired by how far we got with alternative uses of the 1611 converter and MCL2AV in this thread
Knowledge about the BL3500
Link to BW product page: link
Link to BW faq regarding BL3500:
Beolab MKI (originally called LCS 9000) has an 8 pin connector on the back marked MCL. serial numbers are lower than 19343452
Beolab MKII has an 8 pin connector often refered to as powerlink on the back, but according to the servicemanaul for BL3500 MKII only intended for use with Beolink Wireless 1 (W1). No pinout for the connector is shown in the service manual other than pin 6 in the Din connector being data. Serial numbers on BL3500 MKII are from 19343452 and up
Not confirmed knowledge about the BL3500
A user on Reddit
link apparently has a setup with a BL3500 MKI (SW 1.1) where he is injecting 5V from a USB power adapter to turn It on. User Matator has been in contact with this person who has mentioned that the power is connected to pin 1 and 7 on the DIN connector. It has not been possible for Matador, Guy or me to replicate this in our test’s in this thread  Nor with the reverse pin combination (pin 3 and 6) or the dataline and its shield (pin 6 and 7).
Use cases via Beolink Converter 1611 and ML connector Beolab 3500 MKI or MKII connected to Beolink Converter type 1611, two sound inputs controlled with Beo remote via custom cable link thanks to Matador for the great drawing. Use cases via Almando Masterplay and ML connector Beolab 3500 MKI or MKII connected to Almando Masterplay with sound detection input or Powerlink from a B&O music system/B&O TV The product is not for sale from Almando anymore, maybe due to a relativly high price point. I have now (october 2025) acquired this product and from I can tell mine is version I where version II according to the user manual on Almando's web page also has a built in bluetooth receiver. Usermanual for version I: /api/files/38a251bd4c794d38b7e21918d7d04a17 Usermanual for version II from Almando's web page: link The Masterplay unit has DIP switches on the side that has to be set for either automatic sound detection or Power Link The timer function on the BL3500 has to be active for it to work. I have tried both automatic sound detection and Power Link and both seems to work fine. The display on the BL3500 will always show RADIO 1 when active. As for the inner workings of this product as far as I can tell it is using some Masterlink trickery as the data + and - voltages are not +0.25V / - 0.25V as they normally should be. I measured them to +0.22V and -040V which looks more like a not connected Masterlink product. This might also explain why Almando states that only one Beolab 3500 can be connected to the Masterplay. Use cases with MCL/Poverlink connector Beolink 3500 MKI MCL connector Custom cable pinout post number 2 in this thread link Beolab activated with Menu+0+4+GO command. Powers of at any other button press so no volume regulaton on the BL3500 or with remote. The MCL connector can be Can be used this way even though a ML source is also connected to the BL3500   Beolink 3500 MKII PL connector Custom cable Custom cable pinout post number 2 in this thread  Beolab activated with Menu+Menu+0+4+GO command. Powers of at any other button press so no volume regulaton on the BL3500 or with remote. The PL connector can be used this way even though a ML source is also connected to the BL3500
My Beolab 3500 is and MKI (SW 1.2) with the MCL connector. I have used the service manual for the BL3500 (its called LCS9000 servicemanual) available on Beoworld but also a lot of other servicemanuals, and MCL related documentation to get information and inspiration and I will try to mention them as we go along.
To get A baseline for testing I choose to start with a test of the BL3500 in a MCL network as it was supposed to be used to confirm everything working and to know what to expect for certain scenarios. I have a Beomaster 5500 I have used as the audiomaster in the MCL setup.
BM5500 – MCL Cable - BL3500
Tested with both the setting ML off and ML on in the BL3500 service menu (Menu+0+9+GO)
The sources from the BM5500 is controlable, and volume control is possible. This setup seems to be working as expected.
With a multimeter I tried to measure voltages on the different pins, and I got a voltage reading of 4,68 V on the data pin (pin 6) relative to all other pins. The voltage would drop slightly for a second when I turned the system into standby, and then continue at 4,68V. I know that the signal has embedded data, so these measurements might not tell everything.
As we already know that sound input on the MCL port of the BL3500 is possible when a ML source is also connected, I wanted to try if this was also the case if the MCL source has a datasignal.
So I made this setup:
BM5500 – MCL cable – BL3500 – ML cable – 1611 beolink converter – DIN to minjack cable – iphone.
Tested with the setting ML on in the BL3500 service menu (Menu+0+9+GO)
Only the source from the 1611 Beolink converter was available
Tested with the setting ML off in the BL3500 service menu (Menu+0+9+GO)
Beolab 3500 froze and didn’t react to any remote commands at all.
So I guess the conclusion of this test is that the BL3500 can’t handle data signals on both the MCL and ML connector at the same time.
The MCL connector on the BL3500 MKI will accept both speaker level inputs as stated in B&O specifications, and line level inputs as shown in the use case for the MCL connector in post 3 in this thread. I have also made some tests with this connection in this post link
and found out that signal and ground can be reversed.
Looking at the diagram in the Beomaster 5500 servicemanual I discovered that the dataline for the MCL speaker connectors are connected to pin 6 in the AUX din, so I started wondering, could this also be used for connection between the Beomaster 5500 and the Beolab 3500.
As the pinout for those connections are different I made a custom cable:
BM5500 pin 2 - > BL3500 pin 3 and 5
BM5500 pin 1 - > BL3500 pin 1
BM5500 pin 4 - > BL3500 pin 4
BM5500 pin 6 - > BL3500 pin 6
Pin 7 on the BM5500 is datalink for tape and CD, so that is not used for this.
This was not working.
Wondering and going through diagrams and pinouts for the different connectors I noticed that the BL3500 has data shield on pin 7 connected directly to ground internally.
But where should I connect that in my custom cable? Looking at MCL pinout’s answers that question:
Ground on both speaker connectors as well as data shield is all connected which means that pin 3, 5 and 7 in the BL3500 MCL connector all has to be connected:
BM5500 pin 2 - > BL3500 pin 3, 5 and 7
Success
This is working just the same as with the MCL connection :-)
Voltage readings on the data pin (pin 6) are the same 4,68V as I registered with the MCL connection
One thing to note from this test is that the BM5500 is the only product where I have found that the data pins in the Aux connector and the MCL speaker connector are connected internally in the Beomaster, so the result of this test might not be the same with other audiomasters.
One other note that I don’t know if has any relation to this is the description of an obsolete Powerlink cable in the Beolink handbook where it is stated that pin 3 and 7 are short circuited. In my head that doesn’t make much sense in a powerlink cable where pin 3 is signal and 7 is data ground, but might make sense if it was used somehow with the BL3500??
After I found out the pin 3, 5 and 7 has to be connected for the BL3500 to work with data signals and communicate with an audimaster I decided to try this in combination with voltage injection of 5V on pin 6 and 7 and afterwards on pin 1 and 7 with No result. I also tried it in combination with remote control commands as if the 5V would only be enough to get the speaker ready for receiving commands. Also tried it with the BL3500 in option 0.
Open Questions/to be investegated further:
What is the purpose of option 0 on BL3500? I have a hard time seeing a use case. The reference manual mentions option 0 if you wan’t to disable the IR receiver, but not for what purpose.
Can the BL3500 work on the AUX conenctor on other Audimasters? Or the MCL2AV?
Can the BL3500 work with powerlink and the right adapter? Are the datasignals the same?
This thread will be continued with my inputs when time allows it, but hopefully also with other inputs
option 0 is used then you have a wireless 1
with linkeye connected
