Beolab 8000 rubber feet
Hi all Any ideas where I could get rubber feet for the base for Beolab 8000? My 8000s came without rubber feet I would really like to add them since the speakers are standing on a hardwood floor. Thanks!
I am sure the felt pads you buy for furniture in a DIY place will suffice. Did 8000's not come with adjustable feet ?
Felt is an option. Though I use rubber feet by Delock 10 x 3 mm. These fit in size. https://www.delock.com/produkt/18309/kaufen.html
Hello styppen, they are called and are indeed adjustable (I took one from my 8000): But if you cannot find the real ones, maybe you can find some short, flathead M5 bolts (called thumbscrews) and stick a rubber protector on it (one like this:) Then you will still have the possibility to adjust the stance. Good luck! Johan
@Styppen Just to be sure, are you looking only for the rubber feet, or also the metal bolts?
I'm looking for metal bolts with rubber feet. The same as Tignum posted in his first photo. I would really like to get the original replacement parts. If I'm not able to find any, I'll conjure something up with generic bolts and rubber pads :)
Hi again, here they can be bought: https://www.idav.nl/rubberen-voetjes-beolab-8000.html?id=268961159 Not cheap - 50 euros for 8.
Thanks Tignum. Exactly what I'm looking for!
