- Beomaster 5500
- Beovox S45-2
- Beogram 1202
- Airplay streamer
Beolab 8000 Dilemma
Hi Beoworld
I’m in the process of updating and upgrading my home setup. I’ll take the liberty to tell the whole story so bare with me.
Until now, my setup consisted of the following components:
The Beolab 19 will have a very slight delay (4.4 msec) from the 8000s -- DSP takes time vs. analog instant sound. This may not matter if the 8000s have no significant output at those frequencies anyway, to phase-cancel. But in the (unlikely) event you find the bass uncompelling, place the 19 closer to your main listening position than the 8000s by 1.5 meters.
Interesting, I haven't heard about this delay. But I assume if 8000s are connected to the 19 itself the delay should be gone, right?
The delay will only be compensated when you sit straight inline... TV-BL8000-Bl19.
If you sit in different locations not inline you will hear the delay.
Are you sure, that the powerlink socket is a output for other speakers and not input?
It is no good idea to mix analog speakers with DSP driven digital speakers, there is always this disturbing delay. Playing with the runtime of the signal is only suitable for one (small) position in the room where it sounds right. All other positions notice the difference in runtime ... distance and DSP runtime.
Why not using a quite normal analog bass?
Die_Bogener, thanks for pointing this out. You are correct, Beolab 19 only has one powerlink input. I must have confused it with Beolab 11 subwoofer.
Thank you for also pointing out the issue with mixing analog and DSP speakers.
Do you have any suggestions for an analog bass?
This may not matter if the 8000s have no significant output at those frequencies anyway, to phase-cancel. Just use
For music you dont need more than 2 good speakers. Any speaker more makes it worse. Music and something like Dolby 5.1 is not working. It sounds great some hours and then you notice: there is something wrong. Even if it was recorded in Dolby, you will hear the difference, it just takes some time ... and then you will sell it or scrap it. For TV it doesn't care, there is no music, just noise... bumbumrattatatabigbadabooom@ Die Bogener I certainly do not agree! One speaker should be enough ? MMLocation: Flensborg————Danmark
