Beolab 3 with PC - Best solution?
So I just acquired a set of BL3's that I want to use with my PC.
I've seen post with people suggesting the cable from Sounds Heavenly, but a local supplier makes an adaptor that also has a USB trigger.
So what is the best solution?
Hej Jacob
From your name I assume that you are located in Denmark.
The cable solution that you mention probably is from A/V Connection.
That is a trusted solution, that has existed for many years.
I’d say….go local.
Please report your findings here…might help others.
P. S.
Should you however be in the UK….go for Steve’s solution.
