Beolab 14 Sub - IC identification needed !
Hi all - it's been a while since I've been on, I used to be a gold member, however, since I downgraded it wouldn't let me log on, so I've had to create a new log in, hence this is my "1st" post.   Anyway - I have a Beolab 14 sub which has blown a 7 pin IC on the power supply circuit. I know exactly where it is and can see it, however,  I'm unable to identify what the lettering is on it, as the top blew off. Funnily enough, before I discovered the fault I found a small piece of black plastic when dismantling the sub and threw it in the bin, thinking it was just a clip or something that had broken. Having been through 2 full bin bags (I kid you not) trying to locate it, I thought I'd turn to the worldly wise on the forum to see if some kind soul can help. The IC in question is the one at the tip of the pen in the picture. Maybe someone has a Beolab 14 sub on the bench with the innards out, or a used PSU lying around that they could investigate for me ? I'm currently contemplating going through the bin bags again, however, no-one should have to do that twice in their life. I shall spare you the details on the contents. Many thanks in advance - the sub is simple to take apart (some screws on the base), although I certainly wouldn't want someone to open a working sub.
Attachments (1)
Well - would you believe it...
Hey, Just blew the same IC on my Beoplay S8. I'm wondering if you got it replaced and had to change anything else? I don't know if it took other components with it. I've added a couple pics of mine.
Still waiting to get mine back from the chap who’s replacing the blown IC. Thevone he ordered had incorrect pin configuration, so he had to get one in from China.  Fingers crossed nothing else needs replacing, but that’s why I’m having him check it all over rather than me just replace the IC. Ill chase him this week as it should be ready about now.
Would be awesome if you could give an update when you have heard back. I've checked the area, the diode and resistor are both measuring fine.
Will do ! My surrounding area looked a lot less damaged than yours, so it’s good news that your components are testing ok.
Yeah, the diode top has burned slightly, so if you could, I would appreciate if you could send be the numbers on top of your diode. The diode is the one marked in blue.
Attachments (1)
Apologies for the late reply. Sub apparently repaired (IC changed) fully checked over electronically and given a clean bill of health. I’ll hopefully be collecting it tomorrow, so will take some close ups for you. Also managed to find a relatively local Beolab 2 at a sensible price to go with my 8000’s, so happy days all round. If anyone wants a Beolab 14 let me know ! Cheers Jonny
Thanks Jonny! I've ordered the IC chip, so I hope the problem is "as easy" as yours! Would love some pictures when you get it back.
Try these for size
