MMC 6000 Setting Question
Currently have my 4002 up and running again after a much needed damper lubrication and pivot arm cleaning. My receiver has both MM and MC settings. I've noticed the output is lower than my other turntables when on the MM setting. When switched to MC it seems much louder and fuller. I am aware it is often recommended to use the MM setting. Any thoughts on this?
The proper setting is MM. it does have lower output than typical.
thanks pretty much confirms what I have found.
