Beorgram cd 7000 problem
Hi All, My Beogram cd 7000 has stopped working. After pressing the Play button the Track sign light up, the disc spins but it fails to read the tracks and it goes off. When the problem appeared I noticed that that after pressing Play the laser was hitting the back of the case, which could be heard. I changed c2103, 2138, 2140 and the laser stopped hitting the back of the case but is still not reading the disc. I can still change c2104 and 2107 but not sure the problem is in the caps. The laser makes the same movement with or without a cd and it is as if it does not understand a disk has been loaded. Is there anything besides the caps l can check? Re:caps. Can I exchange 47u 10v with 47u 25v? I read that the cdm4 of this cd player is very robust and that it rarely fails. Is it worth changing it at this stage or there are other things l should do first? Which variant of cdm 4 would be acceptable for the BG7000? Thank you in advance for your help.
Did you fit the correct type of capacitor for C2103? It must be a blue Philips/BC axial. Nothing else can be guaranteed to work. Martin
Hi Martin. It is a Nichikon 47u. Can the reason be other then that?
There could be many reasons, but that would be the first on the list. Martin
It is the internal resistor of these blue Philips/BC caps. They are NOT LOW ESR... ... and the player hates LOW ESR for C2103. Replace all and everything whatever you want, but C2103 must be a blue Philips. And check for cracks on the connectors.
Hi All! I am continuing to have issues with my Beogram cd7000 and have replaced all 6 capacitors from Beoparts. The player have played 1 cd and have switched off, and now it does not read any cds. It shows the same behaviour as when I was replacing the c2103 with non Philips components. Any idea what to check next?
Maybe a picutre of the board after modification would help.
Yes sure. Here it is. I checked the soldering today and turned around the red cap supplied by Beoparts. The player started OK but when I moved it to the amp it did not read the cd anymore.
Did you adjust anything? If you didn't - DON'T! If you did - that's why. Martin
No adjustments were made.
