just working on a problem with my BG4000:
the 45rpm does not work !
replaced the speed relay with a modern smd one….no luck.
1TR7 and 8 tested fine, 1TR5 and 6 show 5.85 VDC and 23.8VDC at the collectors.
manual switching from 33 to 45 changes the bulb but platter motor stops.
switching back to 33 platter motor spins as normal again.
what else could be responsible for that issue ?
any pointers or help is most appreciated.
thank you
ALF
