i finally got around to do some work on my Beogram1203:
fitting new motor bearings and the newly designed idler wheel.
the motor sounds fine and quiet but that “knocking noise” seem to come from the
idler wheel assembly and just won’t get away.
It sounds a lots less noisy when I gently push the “speed adjusting” wheel, located on the left side of the plinth.
as I understand the brass tongue which lifts the idler wheel up or down has to sit in
the groove of the idler wheel or did I get this wrong ??
I would be most grateful for some pointers/advice……spent enough time without
eliminating this issue.
thank you
ALF
