When I hit "play" everything works as intended, but the tangential arm itself is moving too slow , After playing 1/3 of a record, the pickup arm is angled towards the center og of the record, maybe 10 to 15 degrees!!!
I cann see, that the spindel itself (the one advancing the tone arm towards the center) is moving in small steps, maybe 1/3 to !/2 a revolution at a time - is that correct or should it be a contious motion?
All buttons on the interface are working correct, but sometimes, the arm takes an extra journiy from back and forth from the start to the end point of travel, when I hit "stop" - could the issues be related?
So far I have replaced both belts, cleaned/lubricated and adjusted everything around the tonearm acording to the service manual.
what am I missing?
