Dear Beoworld,
I need your guys help for my beogram 6500 with following problem:
1. when push PLAY, the pickup carriage system will move left in normal like 1-2 minutes; Then the system will stop in certain position, and the 6500 always play the same sound again and again (because the pickup system is not moving left anymore); As you can check the video 1;
http://v.youku.com/v_show/id_XMTM0NzU2NTY1Ng==.html?from=y1.7-2
(pls copy this link to your browser - sorry for that)
2. when push TURN (left) button, the carriage system is moving very very slow; And to certain position, the whole system is stopped; then if I push the LIFT (Right) button, the pickup carriage system is moving in normal speed; As you can check the video 2;
http://v.youku.com/v_show/id_XMTM0NzU2NjY1Mg==.html
I do some research by myselft, I found the motor (with small belt) to control the pickup left / right have some problem (however, the lamp is normal - it will be ON when I push LEFT / RIGHT button); The motor will just stop after some while for pushing LEFT button; There are must be something to block the motor to run;
Any ideas? I really need some help, I can not find any support in my current place;
Thanks!
Daniel
