I just acquired a beautiful 8002 and have an intermittent issue where the tone arm fails to lift when pressing stop, pause, or at the end of the record. When you press the forward key it will drag the stylus along with the control arm. I can get it to work properly on occasion but it's inconsistent.
The servo belt is fine so that's not the issue. Is this a cap and/or component issue? Anything else I can try before it goes off to the shop?
Thank you in advance!
Larry
