I just purchased a beautiful beogram 8000 from the original owner that had stored it since new.
it worked flawlessly initially but after some further testing the tone arm moves into position but won't drop on its own (it seems to be released as you can tap it and it will drop onto the album).
i checked the belt and it is a little slack so I have anew one coming. My question is twofold.
1) would the servo belt cause the tone arm to not drop? What are possible other causes?
2) how do you gain better access to change the belt? I've removed the black cover under the tone arm but it still doesn't allow very good access to the belt.
thank you,
Larry
