I am hoping someone can offer some suggestions regarding the problem I am having with 8000. Thanks to Martin, I replaced the tach disk and caps, the problem that I am left with I have probably caused. When I power the unit, after a short delay it spins at 33.33 and does not respond to any of the buttons except to change the speed to 45 and to increase or decrease the speed incrementally. The processor power on pin does briefly pulse, if I manually extend the time it pulses, 15 volts is removed and the platter stops and then the buttons work normally, but if I press a button that starts it spinning, then I am back to condition when the unit powers on. If I manually engage the brake (fast down signal to ground) the brake does operate correctly, and stops the platter. Remove the fast down ground and the platter goes back to spinning at the correct speed. All control panel buttons are correctly read at the processor.
I like unusual problems, but I am out of ideas on this one. Any suggestions would sure be appreciated.
Thank-you,
Fred
