Hello fellow Beoworlders,
Thanks once again for your regular support.
I have a question regarding the tone arm height of the Beogram 5005.
I apologise is this question has been asked before, but I have not found a definitive answer to my problem.
The problem that I am having is that when I am playing the newer 180 Gram vinyl records, the stylus is uncomfortably close to the surface of the record. I have in fact heard the needle make contact with the record once while returning to the rest position when it has finished playing. 😉
Another problem I am facing is that on many records (not just 180 Gram) on the last track, there is a scrubbing/scraping noise as the record rotates, sounds like the record is catching on the top left corner of the plater/deck. It is my understanding that there are setscrews under the platter to adjust the suspension (correct me if I'm wrong), but by raising the spatter from the deck, would this then make the other problem by bringing the record closer to the stylus?
My uneducated guess would say that there's an adjustment screw to set the height of the tone arm?
The tone arm currently rests horizontally, and is parallel with the indicator arm when it is in it's raised rest position.
Many thanks in advance.
