The rear adjuster can be reached far easier and with less danger of ruining something by simply removing the plastic trim (the black thing with Beogram xxxx on it) at the rear of the dustcover (only requires the removal of 2 screws and just lifts off!).
Just as an aside, if you need to lift the hood/bonnet, every one I have ever seen have been fitted with a stay/prop which is stored at the rear left corner when not in use.
Thanks, I will remember these points next time 🙂
Spiros, you might still consider trying it yourself as the above advice makes it much easier - the service center will probably charge you quite a bit, and it's always somewhat risky to move these decks anywhere!
