tournedos wrote:
- unplug from mains
- remove platter
- carefully push the arm carriage as far to the left (center) as it will go
- under the right side of the deck, you will find two small screws - remove them
- now the frame of the deck (along with the dust cover) can be lifted up from the right, there are hinges on the left. Look after the tone arm assembly, this is why it needed to be in the center: the top plate cut-out won't clear it otherwise. Be very careful not to let it smash back down, there are no service position supports as in some other B&O gear...
Then you can reach the third leaf spring in the rear. When tilting the top of the deck back down, once again make sure the cover won't scratch the tone arm. Then just push the tone arm back to rest position and see if you got the springs high enough.
I've had to reset all the springs higher on both of my Beograms of this type when I got them to get rid of the scraping. I guess the springs get a little bit saggy with time.
Good advice but I disagree on some parts of the described procedure.
The rear adjuster can be reached far easier and with less danger of ruining something by simply removing the plastic trim (the black thing with Beogram xxxx on it) at the rear of the dustcover (only requires the removal of 2 screws and just lifts off!).
Just as an aside, if you need to lift the hood/bonnet, every one I have ever seen have been fitted with a stay/prop which is stored at the rear left corner when not in use.
Be aware that you are meant to make these adjustments with the arm carriage toward the centre of the turntable.
