Beogram 4004 (Type 5526) issue
Hello! I have replaced all the relays of a Beogram 4004 (Typ. 5526) with new replacements. That said, I am still unable to start the Beogram with the "START" key - only starting by the "33" key. I have re-soldered and the I checked connector P7 and couldn't get a voltage reading, let alone ~30V. I did re-solder R5, D9, R3, and D6 along the path - any ideas?
Hi You wrote that there is no ~30 Volt at the 4000uF Cap? If you try to check the fuses, !!! VERY FIRST PULL THE MAINS JACK !!! there is live voltage connected to the fuses! I would check the fuses first, there are 2 of them in the black housing in front of the Transformator. If they are measuring good close the black fuse housing and plug the mains back in. Next I would  check AC Voltage at P3 PIN 3 and 4. After that check DC Voltage at P3 PIN 1 and 2 (4000 uF Cap) Show us the results. After that we look further. Kind regards Christian
You likely have a shorted transistor in the On portion of the electronic sw. Check TR13 if I remember correctly. There is also a companion on the muting board for the remote.
Thank you both for the replies! I checked the fuses (both are good and were recently replaced). The voltage at the fuses was 123.5V AC. I then checked the DC voltage at P3 - 1 and 2. The voltage was 33.9 VDC I could not get a AC voltage reading at P3 - 3 and 4. I am guessing that this is and issue with my multimeter. I proceeded to replace transistors TR12, 13, and 19. TR13 appears to be the transistor responsible for the "STOP" function and Tr12 the "START" function. Now what happens is the same as before - the Beogram starts with the press of "33" and runs through until the return is activated. This time the return of the carriage is very very slow (as shown briefly in the end of the YouTube video found below). In addition, pressing the ">>" button starts the carriage going in the opposite direction. I am also unable to toggle between "33" and "45" rpm after having pressed "45"... My knowledge of reading schematics is limited, so I really appreciate all the help and patience! https://youtu.be/r58dJxENJUY
There are some major issues there that can only be explained by one or more errors in your parts replacement. Pressing 33 should ONLY cause the platter to rotate and not move the arm. It is a "clean record" function. ON should cause the collector of TR12 to latch high (17v). If pressing 33 is causing that then I would carefully check your diode orientations as you may have one in backwards or a shorted one. The slow return could also be your pulley alignment, lubrication or servo belt.  If it is running at the same speed as ">" then once again there may be a diode/trans issue. This is when TR13 should latch high. Finally, don't forget to check D9/10 and TR8 on the muting board as they perform the same functions.
Hi Mark, Update: TR-19, and IC2 were flipped. I reoriented them and now everything is working, except for “START”. I replaced TR8 on the muting board and applied fresh solder to D9/D10 on the muting board as well - any other ideas?
Glad to see you are making progress. Are you able to start the turntable using the < key to move the arm inward? Does it stay or want to go back and shut off?
Hi What I'd like to know is what orientation is the plug comming from the keyboard to the main PCB? In my case the Red wire should look to the front of the turntable. Can't see clearly in the video. Only to be shure... ;-)) Where did you get this PCB with the 4 SMD Caps? Kind regards Christian
Hi Mark-sf, Yes, the turn table is able to move the arm inward with the "<" key and does stay, without turning off.
Hi Christian, The red wire is at the front of the turn table, as you indicated it should be. The PCB with the 4 SMDs is one of the replacement power boards that I have developed. Ian
