Hello.... first time poster here, please be gentle with me!
I recently bought a Beogram 4002 type 5504 s/n 305887 which was working (but not correctly) and the basic problem seems to centre around the PCB controlling the arm/tracking logic. There are two micro switches which reside behind the control ‘ruler’ which appear to have either been abused or have given up owing to their age. All I found was a number of fragments and other pieces floating around in the area. (See 1st Picture) What on earth that wedge shaped piece of metal is I have no idea but it appears to have been glued somewhere, but I cannot find where! Obviously these two microswitches (see 2nd Picture) need to be replaced but try as I may I cannot find anything similar anywhere. Are these switches a ‘B&O only design’ and if so are they available? Alternatively is the whole board available. As you can imagine, despite looking at the service manual, I cannot be entirely sure of how it all looked originally. Picture 3 shows a similar microswitch, on the arm raising/lowering mechanics, to give you idea how they might have looked..
Can anyone help in either sourcing the switches (Part number 7400115) , or the PCB (PC8009032 or equivalent) or can anyone suggest a ‘re-design’?
I am not liking the idea of this problem beating me..... and don’t like the idea of reading the ‘last rites’ on this iconic over-engineered turntable!
I would be eternally greatful for any help and advice. Thanks in anticiptation!!
I hope this URL to my picture gallery works OK
[View:http://archivedforum2.beoworld.org/members/NigelGee/files/Beogram4002renovation/default.aspx:800:0]
