Beogram 4002 renovation
Hello.... first time poster here, please be gentle with me!
I recently bought a Beogram 4002 type 5504 s/n 305887 which was working (but not correctly) and the basic problem seems to centre around the PCB controlling the arm/tracking logic. There are two micro switches which reside behind the control ‘ruler’ which appear to have either been abused or have given up owing to their age. All I found was a number of fragments and other pieces floating around in the area. (See 1st Picture) What on earth that wedge shaped piece of metal is I have no idea but it appears to have been glued somewhere, but I cannot find where! Obviously these two microswitches (see 2nd Picture) need to be replaced but try as I may I cannot find anything similar anywhere. Are these switches a ‘B&O only design’ and if so are they available? Alternatively is the whole board available. As you can imagine, despite looking at the service manual, I cannot be entirely sure of how it all looked originally. Picture 3 shows  a similar microswitch, on the arm raising/lowering mechanics, to give you idea how they might have looked..
Can anyone help in either sourcing the switches (Part number 7400115) , or the PCB (PC8009032 or equivalent) or can anyone suggest a ‘re-design’?
I am not liking the idea of this problem beating me..... and don’t like the idea of reading the ‘last rites’ on this iconic over-engineered turntable!
I would be eternally greatful for any help and advice. Thanks in anticiptation!!
I hope this URL to my picture gallery works OK
[View:http://archivedforum2.beoworld.org/members/NigelGee/files/Beogram4002renovation/default.aspx:800:0]
I imagine Martin is the chap to ask here! There are not that many who are able to satisfactorily repair these complex machines!
Thanks for that Peter, perhaps Martin will comment if he has seen the posting.
I've seen this cracked plastic head problem many times and so far, I have managed to replace with good switches from donor units but inventory is near depletion.
I would imagine it possible to take out the damaged switch and cast a new plastic head in epoxy (araldite) onto the metal and file it to shape.
Worth trying, I suppose.
Isn't there a tiny spring (plate) missing from one of the switches too ?
I'm sure, it is to be found down the bottom somewhere.
Thank you Martin. The more I look into the remains of this turntable the more broken bits I find. Perhaps there are still more to find :-)
I will certainly try to remove the broken switch and rebuild it....... what would we do without Araldite!?
I'll let you know how I get on!
Thanks again
I would go for new switches, there is a million diff. types out there.
Retired
Printing machine technician
Rock and Roll music
Collecting Vinyl
Oh yes, something in the 33-36 row could be useful, depending on size etc.
Its difficult to see the size on the pic, but 11,13, are very small and would fit in without problem, mostly these switches are guarantied to last more millions work cycles, they are closed and in a TT they will last forever. The actuation arms are easily bent to fit, normally fastened with 2 M3 screws with nut and washer, so 2, 3.5 Mm. holes in the PCB will do it.
Retired
Rock and Roll music
Collecting Vinyl
Thanks Martin and Soren for the suggestion. I think I have already looked at 1 million microswitches on the WWW and there are a few that might fit but the problem could be the alignment...... anyway thanks again....... I nearly bought another one off Ebay tonight.......my interest is turning into a fetish...lol.
Have a good weekend!
Cheers
Hi Folks, just a quick update on this project. Completely by chance I found a solution on EBay where a seller was disposing of PCB from a Beogram 3000, complete with it's power supply, and I couldn't believe my eyes when I spotted three micro contacts of the same type as those that imploded on the 4002.... so all is not lost (hopefully). I have another project on a Beogram 3000, about which more elsewhere! (I'm in trouble again!)
