Beogram 4002 - or 4000 wood replacement
has anyone replaced the wood surround on a 4002? If no any tips? Thanks
  1. Hi
If the wooden surround is still in place on the metal frame you could easyly put a new wood veneer trim on it like this: https://www.ebay.de/itm/264966647721 (google search) I'm not the seller or something like this. This veneer has a paper laminatet backside, is easy to cut with a sharp knife. As glue you could use a kontact cement like Pat..x. Sanding the edges with 180 -320 grid. Spray with semi matte clear coat and enjoy the new look.   Regards Christian
