Beogram 3000 bearings and idler
Seems nice! But why do you heat the oil?
I use the process described
Hello Beogrowler,
can you tell me where you got the new idler wheel from? I think mine is causing some speed issues for my Beocenter 3500 so I'm thinking about chaning it.
Cheers!
From Martin at Beoparts.comHello Beogrowler, can you tell me where you got the new idler wheel from? I think mine is causing some speed issues for my Beocenter 3500 so I'm thinking about chaning it. Cheers!
Great description thanks, very helpful.
How do you guys get the motor centered when reassembling it?
And do you replace the felt?
Peter
Peter
No one? Do you just play it by ear or? ;-)
On another note I'm trying to upgrade my membership to Silver and it seems something is out of order, I'll start a thread about that at the appropriate place.
Peter
I don’t understand your question. It only goes back together one way.No one? Do you just play it by ear or? ;-)
