Beogram 3000 bearings and idler
Beogram 3000 type 5228, 5231, 5241. I just installed the new idler wheel from Martin and infused my bearings with oil and took lots of pictures to share. I’ve struggled with this table going too fast or too slow in the past and received lots of help here for which I’m very thankful. I love this thing.
Beogram supported upside down. Not on the switch or the arm of course.
Motor
3 nuts
2 clips
Screw for switch
Removed motor
I set this close to the table and left the wires attached.
2 nuts for the motor suspension, the 1 on the right is already removed in the photo. This spring motor suspension works great at isolating the noise from the powerful motor and idler.
Removed bracket
Lift springs up off shaft
Here is the location of the two bearings we are going to infuse
Loosen screw on the pyramid of speed control and remove from shaft
Remove the 3 bolts from the motor housing.
Holding the nuts requires a narrow wrench.
Lift off housing
Removed
Pry tabs gently to remove bearings. I pry one less than the other to allow for easier reinstall.
Details of how the two bearings are housed from when you first open them
Bottom
Top
I used SAE 30 oil, like an old VW.
Heated oil added, vacuum sealed following the Beolover YouTube video
I didn’t take pictures of the heating or sealing process incase my significant other were to see what I’m using food prep areas and tools for. Careful handling, hot oil is hot.
