Beogram 1600 cartridge adjustment
Hi
Could you help with the 3 screws in the arm , not sure which one you use for adjustment.
Not sure which adjustment you are seeking. Take a look at this service manual for all. https://beomanuals.com/manuals/Beogram/Beogram%202400/Bang-Olufsen-Beogram_2400-Service-Manual.pdf
Adjustment of what?
Arm does not go down onto record
That could be multiple adjustments. Go through the adjustments detailed in the above service manual.
Part 177 and 1714
Hi
Just got this Beogram 1600
No sound when playing , very odd has last owner said it was ok ?
How are you connecting it? Type of cable - DIN or RCAs? Phono Input on what component?
From the photo, it looks like it is missing the counterweight. That needs to be in place so the arm can be balanced....
