Beogram 1203 motor bearings removal
Hi All,
Can someone guide me through the process of removing (replacing) the top motor bearing of my BG1203 that sits under the stepped pulley ?
no trouble with the bottom bearing  but the top one puzzles me ?
thank you so much ?
ALF
I guess it would have been tricky to explain……the good news is: i worked it out myself.
isn’t that nice ?! ???
ALF
Hi Alf
Maybe you let all others know how you managed the deal with the stepped pulley.
regards
Christian
Hi Christian,
refer to the service manual page 5-7 explosion drawing:
remove motor from the turntable by unscrewing from its 3 anker points and disconnect.
take off idler wheel (one thing less to worry about)
take off the cover - item 184
separate stator from the motor - item 177
remove motor bracket, held in position by 3 rods and secured by one nut - item 164
that frees up the rotor and its bottom bearing - item 178
remove and replace bearing with its oil-soaked felt ring after cleaning.
hope that gave some idea how to remove the bottom bearing
ALF
