I am restoring a couple of Beogram 1000 units and one has its original underside cover with the wiring diagram in the envelope so I know it is a 1000V type 5203 series 8. It has a cylindrical motor. The other unit, which is missing the underside cover, has a rectangular motor.
I am assuming the rectangular motor is a later type. Is it an improved motor and can it be fitted as a unit to the type 5203 or is the chassis different?
With regards to the pick-up, the type 5203 came with a damaged but uncovered pick-up which I assume is the original. I have a brand new packaged B&O "Diamond replacement stylus for SP 1 & SP 2 part number 8905410. Is this suitable to use?
Thanks for any help with this.
