B&O 3D Prints
Here are some of my recent works, originals on the right:
From top to bottom: BC7000 transport screw, BM7000 cable hook, BC7000 PCB holder. Probably the same parts as used in 5500/6500, too? Haven't tested the transport mounts yet, but the other two parts did fit Ok 🙂
I'll share the files when I have properly tested them in place. EDIT: ok, here are the PCB clip and the cable hook: link and . The transport screw didn't quite fit, and I haven't got time to fine-tune it to work properly.
Anyone have high-res photos and measurements of the Beogram CD transport -thingies? My CD7000 has lost them.
I’m interested in the transport locks as well. But for the cd 6500 they seem different.
Yes, I believe the Beogram CD's locks are like this:
Beobuddy wrote:
Orava wrote:
That in the middle
Like this:
Hello Beobuddy,
can you please share your .stl file?
Thanks in advance
Guide Piece for Dust Cover for the BG4000 series:
7" Converter for BG8000 and BG8002:
Hi Beobuddy🤩
Is it possible for you to put you .stl File online?
Having the same problem with a cracked Spindle.
You would make quiet a lot of people lucky
Thank you very much for your advice.
Best Regards
Christian
The Cord Holder for the BeoVox 2500 Cube:
My take on the front grille for the BeoVox CX series:
I just added two file with top- and bottom panels for the LC2 dimmer:
Did you ever get this part (pos 43)?
