Beocenter tape mechanism diagram.
Hello, could anyone who has a Beocenter 8000 tape mechanism belt diagram could share it with me please. Please see attached pic. with the mechanism.
Thank you.
Hi RafH,
No pic. is attached.
But as silver member you can download the service manual from the main page. And as I remember the tape mechanism is the same as the BC9000.
/steffen
Dear Steffen,
I appreciate your prompt response.
I attempted to download the service manual from the main page, but unfortunately, there is no Beocenter 8000 service manual available. I downloaded a service manual from the Beomanuals website; however, I noticed that the tape mechanism in both the BC9000 and BC8000 differs slightly from the one I have. Based on my understanding, I have Version 2 (please refer to the attached pictures - hopefully, I will manage to add them this time) with a shorter belt in comparison to Version 1.
Thank you,
Raf Login to view image Login to view image Login to view image
Raf:
Here's the diagram for version 2 of the mech.
Let me know if you are able to successfully change the belts.
I'm having problems myself. After belt change, transport still doesn't function properly.
Derek
Derek,
I appreciate your prompt response and the diagram you provided. However, I've successfully resolved the issue on my own. I hope you were able to address the issue on your end as well.
Upon installing new belts, I also encountered a problem with the tape mechanism. After a the inspection, I discovered that a plastic lever was broken. I took the initiative to rebuild it as closely to the original as possible. Since then, the tape mechanism has been functioning as intended.
Best regards,
Raf
